Ricoh Mp 3010 "User tools"
  • kalaris
    • 70
    How can I cancel the security code to access the user setup the printer settings. The message "you do not have privileges to use this feature". Using SP mode is possible? Thanks!
  • zed255
    How'd ya manage that?
    • 1024
    After pressing 'User Tools' login to the machine using the username 'admin' (no quotes) and leave the password field empty (blank). Then you should have access to the machine's settings.
    If you need to turn the restrictions off, User Tools>System Settings>Administrator Tools>Administrator Authentication, disable (uncheck / unhighlight) everything there.
