o printRicoh MP161 jamming when making double sided copies
  • tibbs
    • Aug 2008
    • 225
    Hello, i have a Ricoh MP161, when making back to back copies the machine jams when it's taking the paper back in to print the other side. Any help is much appreciated.
  • E Winter
    Check if the juntion gate is working properly. I also had a faulty one way pulley in the right door once - I think it's included in that blue colored gear you can see somewhere near the transfer roller.
    • patrick_aab
      Junior Tech
      • 10
      check to see if the blue gear on the door has worn out causing it too slip. can cause duplex jamming
      • kopikat
        • Jan 2011
        • 15
        i had that blue gear go as well
        • PA5RR
          • Aug 2009
          • 62
          I would go for the one-way blue gear as well, BUT there could be a tiny piece of paper sticking in the duplex . I usually take a piece of cardboardpaper and stick it in the duplex and manually turn the blue gear by hand which often pushes the paperpiece out.
          Good luck!
          technicians are the only ones that don't trust technical stuff !
          • ricoco
            • Jan 2011
            • 122
            I see this model very often and I find this blue clutch defective. In most cases resolve by cleaning the metallic shaft but I advise you to change ... Should not be expensive
