MP5001 (Lanier LD150) jams with SR790 (B408)finisher
  • tonerhead
    • Sep 2009
    • 582
    This will be my 4th time back. I forget what the jam code is but it is always when stapling. The log doesn't show a lot of jams, operator claims jams constantly. I have seen it once, seems to jam right by front white guide (the front of the ones that go up as paper passes into staple tray at lower turnaround) I have taken guides 3,4 out didn't see any nicks or anything. There is a global knowledge base on placing mylars in there, did that. Any thoughts appreciated.
    I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
    Especially when it comes to sex
  • rrowens
    • Jan 2011
    • 17
    I've had something like that on a mp4000, if it's the same finisher. photo sensor GW01 0007 just pass the guide plate wasn't working correctly.
    • bbapst
      • Dec 2008
      • 42
      you say the log doesn't show many jams . Are there any jam code O's (power on jams)?
      • tonerhead
        • Sep 2009
        • 582
        Think I may have figured it out. Found a bulletin on previous version LD050 for input guides for bridge unit. Without these guides you get an occasional dogear. My stapler jams all have one dogearred page. These guides go on some copiers, stay off of others. This model is supposed to have them and doesn't. I got them on order.
        • zico21
          • Mar 2008
          • 58
          Not having these in place will definately cause dog eared pages. The "best" thingis that each of those little blue pieces of plastic cost almost $30 from Ricoh. I complained to our Ricoh Supply Manager and the reply from Japan was that the pricing is correct!
          Come on Fulham!
          • imdandee
            Don't forget to fix or replace those bridge switches!!!!
            • TonerMunkeh
              Professional Moron
              • 3865
              The SR790 wasn't originally meant to run this fast too. There's a modded EPROM out for this. With the dog-eared copy tho, I would suspect those guides too.
              Hit it.
              • rpr383
                • 14
                What we have been seeing on that finisher is at the lower black guide plate (j-shape). The upper part has casting issues. We remove the guide and scothbrite the casting marks smoth and fixes the prob.
                • zed255
                  How'd ya manage that?
                  • 1024
                  I've had to file almost all of those guides on my machines. I've had the missing plastic guides too.
                  • rpr383
                    • 14
                    Yes, they are all just as bad as the next! Some will jam others wont?
                    • zed255
                      • 1024
                      It seems the faster the engine the worse the jamming is. When this finisher first stepped to the 35 and 45 CPM engines we started to have issues, and it has worsened from there. I also find a sligh reduction in the drive belt tension also helps and applying a thin coat of silicone oil to the plastic guides in the 'J' part of the paper path helps too. Filing the ridge off the upper 'J' guide is the big thing though.
