I have a ricoh cl7300 printer which had issues with the colour alignment.
I replaced all PCUs, replaced the transfer belt (and cleaned all rollers in the transfer unit so they are clean and shiny).
Did a colour alignment via the menu - failed
Did a forced alignment via service mode (can't recall the SP) - failed
Ran a dot grid test, colours off vertically (horizontally seem close)
Used the factory settings sheet (in the door under the jam sheet) to reset all settings to those and it worked. However, once the printer went into sleep mode and woke up again, it ran a calibration cycle (seems to do that a lot) and the alignment went off.
Any offers where to look, which SPs to run etc to get this thing functional again?
All help gratefully received!!
