MP 2000 scanner firmware
  • rsyarcia
    Hair Straightener Tech
    • 711
    Address book data error and cannot connect to network appeared on the screen after updating the scanner firmware of MP 2000. We are able to update the other firmwares but only for the scan that we encountered the problem.We downloaded the firmware file from TESSA. Any solution to this problem? thnx to all.
    Nobody is perfect..
  • jonhiker
    • 661
    Try reloading the older firmware. I have seen similiar problems that showed up after updating firmware and were solved by that fix.
    • rsyarcia
      • 711
      OK WE will try that. tnx
      Nobody is perfect..
