Ricoh 3235C Parts Compatible with 3228C Machine?
  • holygrounds
    Our church recently purchased a used 3228C at auction. We later discovered the Printer/Scanner Application SD-card and hard drive(s) had been removed. I was wondering if anyone could tell me if the hard drive and PRT/SCN SD-Card from a 3235C unit would work in our 3228C machine?
    If not, I have also posted a WANTED thread if anyone should have either PRT/SCN SD-card or hard drive compatible with the 3228c for sale.
    Thank you for your help!
  • teebee1234
    • 1670
    The SD card will be different but you probably can get away with using the HDD pack (install them and then format it using sp5-832-1). If you're not familiar with accessing/using the service mode then engage a technician for help. Check your PM for more info from me.
