Ricoh Sp8100dn Network Printing Issu
  • nasrullahbutt
    • 58
    hi dear,
    any one please help me how to remove access control range on interface information
    thanks
  • Eric1968
    • 2458
    Set up a Telnet session to the machine and use the access flush command to reset the access control rannge.
    (Software Guide, page 194)
    • nasrullahbutt
      • 58
      thanks
      dear tell how we change and where its command work
      • Eric1968
        • 2458
        Telnet is used to remotely configure devices. If you're using Windows you must have Telnet installed. It's used from the command line.
        If it's not installed on your system, install it using the Add Software - Enable/Disable Windows Functions. In a command line window type the following :
        telnet IP-adres
        Fill in the login credentials
        access flush
        logout
        That's it.
        • nasrullahbutt
          • 58
          invalid command
          dear please help me i m so tierd for last four days i m working but thier is no result. i want configer four SP 8100 on network but not done.
