Ricoh mp-c3300 drum mod
  • TONERINMYNOSE
    • Aug 2010
    • 114
    Heard there is a mod for these, saw it on this site, now i cant find it. Any ideas? Want to use black drums for color.
  • E Winter
    use the search function - maybe with mpc4000/5000/2800 for the topic title
    • Comatose
      • Jul 2010
      • 70
      Easiest way is to look at the bevel edge on the connector at the back of the black drum, then just use a file to make that bevel on the colour connector, make sure its the same or you will knock the connector at the back of the machine out of place.
      • ricoco
        • Jan 2011
        • 122
        If I understand you want to use the black drum for the colors (I think a matter of cost... it is much cheaper).
        I think now that is not possible. From what I heard they got a way to stop it.
        From what it seems the plug that formerly was held by a screw, now its part of the unit to be enable to switch.
        • ATSBMCO
          Technical
          • Oct 2007
          • 70
          I changed the wiring loom and it was fine.
          • tcs04
            FORMER Techie
            • 1183
            Check out the "Printer" versions, they can be a lot cheaper!
            • rrowens
              • Jan 2011
              • 17
              RICOH BK drums can be mod to work as color drums. It dose cut cost. Some techs that have done says it works fine, others have said it dosen't work well. I'm told ricoh dosen't advise it.
              • venom8976
                • Jan 2011
                • 14
                link
                http://www.copytechnet.com/forums/ri...-5000-a-8.html
