On the bypass tray of this machine the paper is pulled in but stops at the switch before the registration roller. The main paper feed trays work fine and I replaced all of the feed tires. I was wondering if anyone has experienced a problem like this or if anyone has any suggestions as to how to fix this. Any help appreciated, thank you.
Savin 2535
Tags: 253, bypass tray, main, ops, paper, pulled, registration, registration roller, roller, savin, switch, work
Have you replaced the torque limiter and one way's on the bypass? Sounds like one of them is on it's way out.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.
