Ricoh 5560 SC520
  • Vinn
    Ricoh 5560 SC520
    Does anyone know what this error is? Any help would be appreciated.
  • Tech Don
    SC520
    It is the fuser exit motor giving the error code. Check the connections and see if any gears are lock up. Maybe you can reset the code buy do this: press the clear mode button, punch in107 and hold the c/stop key the machine will beep and the lcd will change to the sp mode. then turn the copier off buy using the main switch and back on again. this might clear the code.
    • pbbsinc
      • Nov 2005
      • 92
      the most common cause of this code is one of the bearings in the fuser binding up or the press rlr cleaning roller excessively dirty.
      jay
      • kittymor
        I've seen this code when the fuser locks up because the hot roller disintegrated...fuser rebuild HR+ heat belt minimum. good luck
