Sc 672 on Ricoh 1232c
  • acemarch
    • Jul 2025
    Hi I have a ricoh 1232c and all of a sudden it started giving sc 672 error, the recession has taken its toll and we are not in a position to call a tech to fix it. ANy guidance to get the issue fixed is appreciated. Thanks
  • Warren
    This is an extract from the service manual it could also be faulty ram dimm
    make sure you allow the connections to dry before reinstalling in the machine
    CAUSE
    Poor contact between the controller board DIMMs and connectors, caused by dust and
    other particles that can be attracted to the contact areas.
    SOLUTION
    Check the contact points described below for each symptom, then remove the DIMMs and
    clean the DIMM terminals with alcohol.
    Symptom: Contact Points to Check/Clean:
    SC672 (Controller-to-operation panel
    communication error at startup)
    CN4: Memory DIMM
    CN6 (Slot 1): Printer / Scanner controller
    • Jomama46
      • 2900
      Yep, clean the memory and ROM DIMMs
      sigpic
      A+; Network +; PDI+
      • acemarch
        Thanks a Lot you are a legend the problem is solved. Once Again Thank you
