Ricoh CL7200 + IS300e has Error SC541, but I can't clear the error
  • Jeremy-Ricoh
    • Oct 2007
    • 24
    Hi there, this is my first post.
    My Ricoh Aficio CL7200 has error code SC541. Some how paper got jammed in the fuser's connection. After clearing the paper, and rebooting it still comes up with this error.
    I did a search and found LaserSharp had this problem last month on his 7200.
    The problem is the scanner on my 7200 doesn't seem to communicate with the printer. When doing "Clear, 1,0,7, hold stop for 5 seconds" it gives Scanner related options.
    Is there a way to clear the code without the scanner? Or do I need to do something special to make the scanner talk to the printer?
    Thanks.
  • The Real JB
    Thanks.
    Hi - Ricoh had a LOT of trouble with their El-Cheapo scanners. They are so fragile that sometimes just shipping them, or even relocating them with slight bumps, prevented them from working. Ricoh would never tell you this, but then again the truth escapes Ricoh quite often. I, on the other hand, have no trouble with the truth.
    • Anders Nilsson
      • 33
      Reset SC 541
      Loose connection of
      the heating roller
      thermistor
      Defective heating roller
      thermistor
      Defective BCU
      1. Check if the heating roller thermistor
      is firmly connected.
      2. Replace the fusing unit.
      3. Replace the BCU.
      Controller
      errors CTL The error has occurred in the
      controller.
      See .Troubleshooting Procedure. in
      the table.
      A
      The error involves the fusing unit.
      The machine operation is disabled.
      The user cannot reset the error.
      Turn the main switch off and on.
      Reset the SC (set SP5-810-1). Turn
      B
      The error involves one or some
      specific units. The machine
      operates as usual, excluding the
      related units.
      Turn the operation switch off and
      on.
      C
      The error is logged. The SC-code
      history is updated. The machine
      operates as usual.
      The SC will not show. Only the SC
      history is updated.
      Other
      errors
      D
      You can reset the machine by
      turning the operation switch or main
      switch off and on. If the error occurs
      again, the same SC code is
      displayed.
      Turn the operation switch or main
      power switch off and on.
      • Jeremy-Ricoh
        • Oct 2007
        • 24
        Thank you for the information!
        As it turns out I was able to clear the code (It might have been SP5-810-1), and all is fine now.
        • AHMED
          SC541
          Thermistor Of Fusion Opened
