RICOH Priport Jp755 ..E-00
  • sweet.persona
    Engineer
    • Nov 2009
    • 415
    [Error Code] RICOH Priport Jp755 ..E-00
    Hello friends
    i have a problem in Ricoh priport JP755; When i make a scan it post up E-00
    which is an error.
    -how can i enter to the "mode save" of this duplocator?!
    -Can i reset it? or this code is about something else?
    I wish to get some help from any member " technicians"
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • sweet.persona
    Engineer
    • Nov 2009
    • 415
    DAMENE ABDEL AZIZ
    DJELFA
    • Aries_1
      • 42
      From what I remember, E-00 has to do with the clamper. Without getting too technical, make sure everything is ok with the drum clamp and clamper motor/gears in the back of the machine, then restart the machine. The code will clear on restart.
      • sweet.persona
        Engineer
        • Nov 2009
        • 415
        thanks alot dear friend aries_1 tomorrow i'll try .
        DAMENE ABDEL AZIZ
        DJELFA
        • sweet.persona
          Engineer
          • Nov 2009
          • 415
          it's sucessful but it is not printing!!
          what is the problem!
          the scanner it's okay but when i see the drum .there is no writing!!!!
          DAMENE ABDEL AZIZ
          DJELFA
          • rsyarcia
            Hair Straightener Tech
            • 711
            what do you mean you can not see writing on the drum? maybe you mean there is no master wrapped around the drum? or maybe during master making the clamper missed the master but there should be an error message. Just check the clamper assy, make sure that all sensors are attached and clean.
            Nobody is perfect..
            • sweet.persona
              Engineer
              • Nov 2009
              • 415
              Every thing is okay but there is no writing on top of master !!
              DAMENE ABDEL AZIZ
              DJELFA
              • rsyarcia
                • 711
                have you tried the image adjustment
                Nobody is perfect..
                • sweet.persona
                  Engineer
                  • Nov 2009
                  • 415
                  The master is Not carved and the paper gets out without being printed !!so what is this prb pls!!
                  DAMENE ABDEL AZIZ
                  DJELFA
                  • rsyarcia
                    • 711
                    if you mean there is no printed(holes) image on the master then check for the scanning and the thermal head
                    Nobody is perfect..
                    • sweet.persona
                      Engineer
                      • Nov 2009
                      • 415
                      it is weired i do not founed the solution , THERE IS NO WRITING !!!!!
                      DAMENE ABDEL AZIZ
                      DJELFA
                      • sweet.persona
                        Engineer
                        • Nov 2009
                        • 415
                        any help!!
                        DAMENE ABDEL AZIZ
                        DJELFA
                        • rsyarcia
                          • 711
                          Could you please perforn image pattern print -SP6-42. This will determine if the thermal head or the scanner is the problem.
                          Nobody is perfect..
                          • TonerMunkeh
                            Professional Moron
                            • 3865
                            Originally posted by sweet.persona
                            any help!!
                            Might be time to call a tech.
                            Hit it.
                            • Codex
                              • May 2008
                              • 701
                              Hello
                              i think it's a problem with the thermal head, give me the part number, i think a have a new one( Never used) , but check also the wires and harness to the head.
                              Memento Audere Semper
