2238c Color boarder line
  • Ricoh Dicoh
    • Dec 2010
    • 62
    2238c color copies coming out with a boarder around every part of the image. Looks kinda like a 3d image without the 3d glasses on. Black and white copies are fine. But when you put a black and white copy with a color copy (testing purposes) the black and white part of the copy will have an outline coloring as well.
  • teebee1234
    • Jul 2008
    • 1670
    The color registration is off. First make sure you have cleaned the MUSIC sensors, the transfer belt is undamaged and the silver roller at the top left edge (as you face it from the front-under the transfer belt) is scrubbed clean and all of the color densities are within range. Do a color registration adjustment in user tools and if that fails follow these easy directions to correct it.....
    • Ricoh Dicoh
      • Dec 2010
      • 62
      Thank you for your assistance. What/Where are MUSIC sensors?
      • Ricoh Dicoh
        • Dec 2010
        • 62
        Also on the first page of the flow chart it says under if skewed/criss-crossed about 5 info boxes down to set SP 2-908-3,4,2 to factory data sheet*. What is this referring to?
        • Ricoh Dicoh
          • Dec 2010
          • 62
          Just noticed the side not that says "Factory data sheet is located inside front cover. Use a value of 0 if no data is found.". Is it talking about the front cover of the service manual or where ever these instructions come from? I know i can figure this out no problem but I am just curious.
          • TonerMunkeh
            Professional Moron
            • 3865
            The birth certificate of the machine, it'll be hiding in the front cover somewhere, single sheet of A4.
            Hit it.
            • Ricoh Dicoh
              • Dec 2010
              • 62
              Ok so I'm going to sp 5-997 to do a test print out and all that's coming out is a full black page? What am i doing wrong here?
              • Ricoh Dicoh
                • Dec 2010
                • 62
                ok figured that little problem out but now when i try and do the forced line adj (sP5-993-2) It fails the operation. Not sure if i should keep going on as instructed or if i have to do something to make it say completed
                • pLatik
                  • 169
                  you have to keep going all the steps in this technical bulletin, until your machine says "completed" in the forced line adjustment.
                  • Ricoh Dicoh
                    • Dec 2010
                    • 62
                    Got it thanks for all the help
