FollowMme Application
  • ricoco
    • Jan 2011
    • 122
    Anyone have any experience with application "FollowMe"?
    Where to install the application and how it works.
    As a user you've seen how it works associated with the "PCC " but I wonder how the technical level.
    What is the difference with AppToMe?
    Sorry if I'm making a huge mess but if someone gives me a light I am grateful.
    I like to understand the concept
  • huberto233
    • Nov 2008
    • 40
    Basics
    AppToMe is just about customizing an operation panel for users so they can use different widgets / icons . Follow me printing is not an application it's just a function build in some more advanced software as for instance Equitrac allowing users to get their prints jobs sent to a virtual queue and collect of any machine set up on that software. I think there are the basics.
    Network+,
    • ricoco
      • Jan 2011
      • 122
      ok.
      Question: Can We use the follow me scaning with Equitrac?
      • huberto233
        • Nov 2008
        • 40
        This is called Scan-To-ME which basically means you can set up scan to email on Equitrac and then using PCC 4 you can start sending your scans
        Network+,
        • ricoco
          • Jan 2011
          • 122
          Works well ????? You have done it??
          I have a client who complains of a malfunction. The scans appear sideways ... How can I change this?
          • huberto233
            • Nov 2008
            • 40
            Network+,
            • ricoco
              • Jan 2011
              • 122
              Once it's set up it works well. Customer may have an access to change the setting to scanned documents but the Equitrac must have the proper box ticked.
              "In Equitrac’s System Manager, click Configuration in the left pane. The right panel displays device information."
              "Option Description
              Enable configuration button
              When enabled, adds a Configuration button to the main Scanto-
              Me screen in PCC. Users can click on the button to change
              scan settings."
              Thank you.
              I'll try to get a license to install on my virtual machine. I'll try to study the issue and then go to the customer.
              Maybe I will ask you for more help after the license. I hope you do not mind.
