Gestetner 635 (Aficio 2035)
  • RonMac
    • Oct 2008
    • 57
    Any information appreciated on error code 990 which is a software performance issue. Thanks. Ron
  • TonerMunkeh
    Professional Moron
    • 3865
    When's the last time it had a PCU rebuild? A worn drum can cause this fault.
    Hit it.
    • GeorgeK
      • Sep 2008
      • 23
      Affirmative. TRY xerographic pm, and correct setting, td-id, before start scratching soft.
      TECHNICIAN noon. (tek~nish~uh n)
      A person who fixes the mistakes made by engineers.
      • CrapAimer
        • 296
        Worn out drum, Developer and door switches cause this fault
        • Jomama46
          • 2900
          the switches above the fuser are notorious for collecting toner and causing this fault.
          sigpic
          A+; Network +; PDI+
          • ccchuah
            • Mar 2009
            • 159
            Try reformatted or replace the harddisk after replaced the drum.
            • RonMac
              • Oct 2008
              • 57
              Thanks to all of you for your help in solving the error 990 code on the Gestetner 635. I did a PM, replaced drum and DV. Works great! Thanks again.
