mpc 4000
  • T911
    • Jun 2007
    • 628
    mpc 4000
    I have the bypass locked in printer mode. Copy mode I can change. Is this admin or a simple printer property setting. Do I need admin code if so what would the admin code be. Thanks t
  • TonerMunkeh
    Professional Moron
    • 3865
    Bypass locked as in you can't change the paper size or it's just not there?
    Hit it.
    • T911
      • Jun 2007
      • 628
      Can't change. And one of the trays vanished.
      • jonhiker
        • 661
        Have you check the driver settings? if these options are not enabled, they will not work. It might not be a bad idea to delete the printer and re-install
        • TonerMunkeh
          Professional Moron
          • 3865
          Yeah, sounds like a driver issue. Wrong one perhaps?
          Hit it.
          • ricoco
            • Jan 2011
            • 122
            I do not know if I understand your question.
            In my opinion you should follow the suggestions but if you can to change the paper size on by-pass you can click on the # key (after putting the paper)
            • T911
              • Jun 2007
              • 628
              i'll try to do the reinstall first and let you know. thanks t
              • teebee1234
                • Jul 2008
                • 1670
                Don't forget, what the display is showing for bypass size in printer mode is what the default setting is for the bypass and not driver related. Typically you can change that in printer user tools. Driver commands for paper size override the printer settings (unless changed in the user tools). So even if it shows 8.5x11 on the copier display, if you send a 8.5x14 document then that is what the printer is expecting to be put in the bypass tray. The main issue is when sending a letter size document that you put it in the right orientation (though I notice that the MPC4501 has an auto detect setting for the bypass tray, which only determines the orientation of the letter - landscape or portrait).
