I cannot find the p/n for the K pcu for this model , it s not on tessa or in the parts manual- can anyone help pls.
AP3800c
Generally that's considered a supply item that the customer would purchase and put in, being a printer. I don't believe there is a part number for the black but there is for the color pcu. The part number for the color pcu is G0602219 (original part number, may have changed since then) and should work ok for black, but I seem to recall there might be a difference in the waste auger nozzle length on the rear (you would need to check that first before hand). The EDP code as a supply order for the black pcu is 400548. -
I don't think there is any difference in the OPC (drum), just the casing between a colour PCU and black. These machines have a separate PCU and dev unit for each colour, so you'd only be replacing the 'drum' side. The three colour PCUs are supplied in a kit and the black PCU is a separate item, sorry I don't have the EDP codes handy.Comment
