Web roller on mp 5000
  • sebreizh
    • Oct 2009
    • 28
    Hello, I have a problem on a photocopier Infotec MP 5000. I get the message "change the web cleaning. I felt this change and makes the code to clear the fault (SP7-806-008). The message is still displayed. Can you help me?
    Thank you
  • sg01
    • 16
    Thank you
    You can't do away with this prompt even with the reset. The Cleaning Web located with the fusing unit has to be changed as the lever sensor sense it's running low. Soon it will prompt sc 550.
    Replace with AE04 5099 Cleaning web, 160k prints.
    Functional after will be good.
    • teebee1234
      • 1670
      If you're saying you replaced (felt) the web then you have reset the web consumption back to "0" - (SP1-902-1), also reset 7-804-5 (web pm counter) and 7-806-8 (web parts counter).
      • TonerMunkeh
        Professional Moron
        • 3865
        This caught me out the other day. Resetting 1902-001 doesn't reset the message, you've got to do both the parts counter clears and reboot to get rid of the message. The Alex must DIE.
        Hit it.
        • teebee1234
          • 1670
          Oh yes, the reboot. Totally forgot about that step, it seems after years of things getting simpler now the pendulum is starting to swing the other way.
          • sebreizh
            • Oct 2009
            • 28
            Thank you, the code SP7-804-005 remove the default. Thank you all
            • sebreizh
              • Oct 2009
              • 28
              Thank.
