a tech I once worked with told me when doing the ACC procedure, that it was best to do the printer patterns first then the copier pattern last and gave me a reason why blah blah blah (is a good tech, no disrespect meant). What is everyone else out there doing and does it matter which is done first
ACC Procedure
I dunno if it makes a difference but I just do them in the order they are on the display, starting at copier then lowest dpi to highest for printer.
Be interested if someone could explain any reason for using another sequence.I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison -
something to do with getting an optimum print quality before doing the copy pattern, (it was probably an idea that started with earlier models) .Thanks for answersComment
