3245C Red lines
  • Rick
    • Mar 2007
    • 277
    3245C Red lines
    I have been dealing with these red lines on this machine and I cant get to the bottom of it.
    The pcr keeps getting contaminated . I just clean the pcr with alcohol and its
    ok for another week . I have quite a few of these units in the field and this is the only one doing this. Any ideas anyone ?
  • Jomama46
    • 2900
    Cleaning is very temporary. Either replace it or perhaps coat the pcr with turtle wax.
    sigpic
    A+; Network +; PDI+
    • Rick
      • Mar 2007
      • 277
      I have replaced the pcu 3 times . But I have never heard of coating it with turtle wax . Does it work ?
      • Jomama46
        • 2900
        You'll get lots of opinions, mine is, replace the PCU
        sigpic
        A+; Network +; PDI+
        • Rick
          • Mar 2007
          • 277
          I did replace the PCU it only lasts a week.
          • Jomama46
            • 2900
            I guess I would look at the developer clutch, it may be sticky and turning all the time. Is Magenta a primary color that they use? Are they going thru a lot of M toner? Are they using Genuine M toner, Genuine M PCU? Or Rebuilt?
            sigpic
            A+; Network +; PDI+
            • Rick
              • Mar 2007
              • 277
              They arent using any noticable increase in m toner and we are using oem parts and supplies.
              • pLatik
                • 169
                And what if the customer use primary magenta toner in is impressions? what could happen in this cases, jomama46? i ask, because i have a customer in this condition, and i like been prepared to any issue that could happen. parts are oem, toner not oem.
                • Jomama46
                  • 2900
                  3rd party toner will always be a problem if for no other reason than you dont know whether it is the problem or not. It is usually cheaper because it isnt manufactured to the highest standards. The particle size can be too small or too large or not a fixed size at all. Maybe even different materials.
                  If your customer is using one color more than others, you can expect to replace the pcu more often. My bos uses Cyan like crazy in the showroom and the pcu usage shows it.
                  Rick, try replacing the developer clutch.
                  sigpic
                  A+; Network +; PDI+
                  • CableGuy
                    Impulse Drive Engineer
                    • Oct 2008
                    • 417
                    Can you post some examples of the marks?
                    • Rick
                      • Mar 2007
                      • 277
                      The marks are refered to as tiger stripes . I will get some samples for you to look at.
                      • tcs04
                        FORMER Techie
                        • 1183
                        Similar to attached??
                        • Rick
                          • Mar 2007
                          • 277
                          I will get some samples tomorow
