SP8200 DN... UK maintenance kits, do they exist?
Aye, the maintenance kits aren't available to us poor saps in the UK. Oddly enough, they are everywhere else in the world. With regard to switching the counters off, you can't. There is an SP mode to stop it shouting at @remote for the kits, but that's not much use!It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it. -
I dont know if i understand your problem but you can desable the alarm in the @remote by turning 0 the SP 5-507-010 and 011.
Also there is a firmware release (system) that fix the problem of incorrect calls to change the main kit A and B. Take a look in the tessa and you will see the posts and the firmware.
I dont use the main kit A and B. I use the main kit for the MP4000. They chare the same compunents and it is much sheaper.Comment
How much is a Fusing Unit???
Now, tell me if you allways need to change all parts of the Fuser... Mostly you change only the web (if at the end) when the Main Kit appears.
How much is a Transfer Unit???
You just need to change the blade and belt.
See what i mean???Comment
I totally agree with you. BUT!!!!
pissbull
Maintenance Kit B
Hi, I know these machines fairly well and if you want to clear maintenance kit B you need to change the fusing web and do the necessary sp mode changes you'd normally do changing a web. then do a pm count reset for the fuser and you're back in action
for maintenance kit A, this is just the PCD so a pm count reset for PCD will clear the error state.
When the model first came out there was a setting within general settings which allowed the printer to continue printing even in this error state but the option mysteriously dissapeared during one of the firmware upgradesComment
