error sc 390 aficio 2020
  • BAAKLINIELIAS
    • Jun 2025
    hello ,i put new compatible toner then the copier after 50 copies give this error , how can i resolve it ,do i need a new developer,or i can change only the toner? thanks.
  • jonhiker
    • 661
    390 B TD sensor error
    The TD sensor outputs less than 0.2 V
    or more than 4.0 V 10 times
    consecutively during copying.
    TD sensor abnormal
    Poor connection of the PCU
    I would suggest new toner, preferrebly OEM and a new developer. it might need a new TD sensor or DV unit.
    • BAAKLINIELIAS
      thanks, do i need to reset this code also ,if u now, how?
