dirty copies Aficio 2075
  • kalaris
    • 70
    I have basic problems and scattering toner on a Ricoh 2075. After replacing developer, drum blade and brush after a few hundred copies, was presented a gray background and found accumulation of toner and drum in driving time between magnetic roller, hidden code SC 455.
    Has anyone had similar problem?
  • CT Copier Repair
    • Mar 2010
    • 304
    Did you replace the developer seals
    machine leaks toner like a sieve and did you set the developer correctly with ricohs if you do not get the dev set 1st shot they are overtoned machines and with background on copies it sounds like its overtoned
    run some sky shots and try to set tdc
    • JustManuals
      • Jan 2006
      • 9838
      Just Manuals | The Internet's largest collection of manuals | Instant Downloads
      Paul@justmanuals.com
      • RRodgers
        • Jun 2009
        • 1947
        Really?
        • RRodgers
          • Jun 2009
          • 1947
          When you changed the Dev, did you put the piece of paper inbetween the drum unit and the dev unit before you ran the td code? Ya GOT'S to do that.
          • ddude
            General Troublemaker
            • 473
            Really?
            HA!
            2000 mockingbirds = 2 kilomockingbirds
            • kalaris
              • 70
              I do not usually drive the paper between the drum and developer, I have never given this problem, I also downloaded unit toner to remove any defective toner.
