2015/2018 nvram question
  • ponto700
    • 144
    Hi,
    I have one 2018 and the ram was demage (sc 541, sc 903). i bought one new ram and i put on the machine and the part number is 1407-5299. When i power on i got sc 903 but strange is this nvram is new ( 0 counter).
    i check on part cataloge and the part numer is correct.
    I took out the nvram from one 2020d and i put on the 2018 and machines works fine... did anyone already have this problem with a brand new nvram?
    thanks
  • TonerMunkeh
    Professional Moron
    • 3865
    A duff NVram caused SC541?
    Hit it.
    • ponto700
      • 144
      look strange but yes, i got that error with the nvram demage!
      • rsyarcia
        Hair Straightener Tech
        • 711
        Have you tried to put that new nvram or used the old one to other machines? we encountered one problem with MP 1600. SC 541 cant be reset even we changed the whole fusing unit and PS. We changed the BICU then ok.
        Nobody is perfect..
        • ponto700
          • 144
          yes, i put a both nvram on one 2020 and still have same problem... i put the nvram from 2020 (working machine) on the 2018 and all fine. tomorrow i will change the new nvram where i bought it from and them i post here the results.
          thanks!
          • ccchuah
            • Mar 2009
            • 155
            Did you execute memory all clear for setting NVRAM to default setting first ?
            • Jomama46
              • 2900
              Did you install the serial number for the machine into the new NVRAM?
              sigpic
              A+; Network +; PDI+
              • Codex
                • May 2008
                • 701
                check on the controller if there is any switch or jumper, i remember something like this on a 2022/27
                Memento Audere Semper
                • ponto700
                  • 144
                  finaly problem was solved... i put other nvram, execute memory all clear and after power on the machine again no more errors.
                  machine is working fine now.
                  thanks to all.
