sc 320,322,326
  • kamal
    • May 2025
    [Error Code] sc 320,322,326
    always appear sc code 320,322,326 one by one for af1035,plz help me to settle it down
  • JustManuals
    • Jan 2006
    • 9838
    Paul@justmanuals.com
    • wfinn
      • Mar 2011
      • 70
      Sounds like you have a bad laser unit. Possibility might just be the mirror motor but normally that just throws a 320. If its not spinning at speed that could also give you the sync problem your getting as well. With the age of that machine and the laser unit in it, its hard to tell if its just the motor or something wrong in the unit.
      • igorbirokip
        • 24
        90% You need to replace GENUINE RICOH AFICIO 1035 LASER UNIT - Polygon Mirror Motor With Circuit Board Genuine Ricoh Part
        Ricoh AX06-0141, AX06-0303, AX060303, AX060141
        10% But before replace , clean laser top and glass cube on LD look on image
        • Vanya
          Day kind friends!!!
          Problem with 322,326 TH has solved, there is nothing difficult. I will in detail write on mail. My mail vanya.schastlivchik@yandex.ua
