Ricoh Aficio MP2550 power-up problem
  • zoran.riko
    • 54
    When power-up the machine only green light ( stand-by ) lit. Nothing happends, no display
    Fuses on PS board OK.
    Any sugestions pls
  • ricoco
    • Jan 2011
    • 122
    Any sugestions pls
    You can take a copy?
    • stan780953
      • Feb 2011
      • 47
      Try taking the HDD out and reboot. If it comes to ready you can try formatting the HDD.
      • zoran.riko
        • 54
        Nothing on OP Panel, like totaly dead
        • Blazer1087
          • 195
          In a case like this I would remove all options like Fax, HDD,etc and try it then. If it works as a copier than reinstall one component at a time to see what happens. Like stan said I have had an HDD cause this type of issue. good luck
          • zoran.riko
            • 54
            When the main switch is turned on only green light on the right uper corner on the operation panel is lit and nothing else is happening. Lcd is black, no motor or something else is hapening. Controler is switched with other from other machine and same....
            • jonhiker
              • 661
              try swapping out the power supply, even though the fuses are good.
              • ricoco
                • Jan 2011
                • 122
                Try to access to WIM. If you can maybe you see the error or a SC (service code)
                • zoran.riko
                  • 54
                  SOLVED
                  SOLVED, it was the Power Supply Board.
                  Thanks everyone for threats
