Missing yellow color mpc2500
  • Dis
    • Mar 2011
    • 35
    #16
    Originally posted by Gift
    Stop the machine during printing a full yellow page / large format and see if the toner image looks ok on the drum - in this case it would have nothing to do with the transfer unit. The laser shutter issue may be a reason as well as other possible problems within the PCU (improper contact of the charge roller...).
    support on this ways testing~~
    • Apprentice
      • 5
      #17
      Why not swap first the the drum portion of the yellow PCU unit with the other color to isolate the problem.
      • jivedancer
        • Apr 2011
        • 14
        #18
        Broken cable bias terminal within the ITB unit causes issues with yellow transfer usually no yellow
        • Sashko
          • Oct 2009
          • 110
          #19
          I agree with Zeldman.
          First you must update the firmware for BICU and System/Copy!
          I had same problem on this machine but with another colour - black and cyan.
          I had checked all components (PCU's, laser diodes, laser unit, transfer belt etc).
          Before replacing the BICU board I updated the firmware for it and... this solved problem!
