After shipping Ricoh Aficio 3045, now all covers indicate "open" to system - help!
  • BWB8771
    • Mar 2011
    • 49
    We moved the unit as part of buying another company, and plan to sell it.
    Upon powering-up, the device is indicating the Printer, Copier, Fax, and Scanner covers are open, when they are very definitely closed.
    Is there a reset code/function?
    I know these monstrous multifunction units do *not* like to be moved, so it is at all possible that we warped/twisted the "chassis" that's offset all the sensors' registrations?
  • daveyball
    • May 2009
    • 314
    could be all sorts, did the machine have an LCT that didn't ship for example, there will be a gap below the duplex, take a photo of the display and post it, it may give us more of an idea
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • tcs04
        FORMER Techie
        • 1183
        Make sure the laser safety switches are wired in the correct sequence, use the PtoP and trace the circuit through each connection.
        • jonw
          • 57
          open front door above fuser unit there are 3 switches .when one starts to short will show door open but not a location.. WD40.........
          • Wireless Man
            Re: After shipping Ricoh Aficio 3045, now all covers indicate "open" to system - help
            check also all fuses on power supply..good luck bro
            • hugojulio@ig.com.br
              • Jul 2011
              • 3
              Check and / or replace the ribbon cable from the polygon motor that is in optics.
