Problemi with Ricoh FT 4615 - please help me
  • menzog
    Hello and congratulations for the forum, I was of help tonight. I have a problem, I just changed the drum, developer and toner ricoh as the object but the results were not what you want, the first problem was to accept the new developer and I have resolved with SP mode 66, but the real problem is that the photocopies are gray and not complete, I try to explain with an example: imagine having to copy an A4 page with a black color, well done goes out to the photocopy and light areas and dark areas in some parts of the toner just missing (white sheet). What can I do to fix this problem? someone has all the codes for this machine sp? thanks in advance.
  • CT Copier Repair
    • Mar 2010
    • 304
    Its called developer calibration and it sounds like it hasn't been done right
    so replace the developer restring the coronnas and R&R the drum and cleaning blade
    if you do not know how to do this then call a tech as you are going to strip the developer immediately and it can;t be recovered
    • tcs04
      FORMER Techie
      • 1183
      What were the copies like before you changed the parts?
      • menzog
        The copies before that I changed all parts were blanks and some part of the paper were stained with toner. What can I do to fix this problem? Do you have an idea? I tried to put another developer in addition to the new, but never, even if the party that is copied has become black, but the rest has the same problem.thanks
        • menzog
          Thank you for the answer, after that i maked the new developer, toner and drum I set the machine in SP mode 66 (developer calibration) for set up the new developer, I just waited 60 seconds and after I push the power off button same as technical manual advice, do you think that I I have done something wrong?? excuse me for the question, but, what is the exact procedure to do this?
