scan to folder ap 3260c
  • pukiro
    • Feb 2011
    • 59
    I have a aficio 3260c problem with setting up scan to folder...
    i have set the path correctly and put in the user name pasword in the smtp auth.
    and when i do a network test it comes back as failed...
    net bios, sharing is all active and working correctly....
  • zed255
    How'd ya manage that?
    • 1025
    Be sure your firmwares are up to date. If you are trying to scan to a newer OS that uses NTLMv2 by default (like Windows Server 2008, Vista or Windows 7) and the network firmware is out of date the copier won't establish a connection to the share.
    • ricoco
      • Jan 2011
      • 122
      I am sory my question... But, way did you put the password in the SMTP auth????
      Arent you trying to scan-to-folder????
      Did you saw the authentication for the folder??? (user login and password)
      • Comatose
        • Jul 2010
        • 70
        Have had some problems before where even though the path was correct i.e \\myserver\scans it would fail a connection test. Try using the sever IP address instead of server name, this has always work for me
        • mikedci
          • Jul 2010
          • 227
          Assuming firmware is up to date and you meant smb and not smtp, check the firwall settings to make sure thats not blocking it.
