When sending fax, it will show transmitting but after awhile it will hang. Already tried to clear memory but still cannot work. Anybody can share some knowledge ? Thanks
Ricoh Aficio 2045e fax board not working
Try disabling ECM via service bit switches, I don't recall precisely which one - refer to the manual. This will automatically disable all the 'high speed' protocols. Sometimes if line conditions are variable the unit will negotiate a speed higher than the line can actually sustain. The result is a lot of Tx errors and retries. -
