This one has a gbc stream feed III on it. At the entrance gate of the gbc the gate and solenoid go crazy sometimes jamming of course. I can do a run of 100 to 200 no problem and then do the same runs but then it goes crazy. I will post the firmware in a while but could this be mechanical with the solenoid or you think its the signal or fw. I removed the gbc and reinstalled the sr5000 so they can use the machine. Thanks t
mpc 7500
