Ricoh Pro C720 - Weight Issue
  • Lloyd Davies
    • Aug 2025
    Hi Guys,
    I'm new to the site - Registered this morning (17/3/11).
    Not your average question, but here goes...
    A client of mine is looking to implement a Ricoh Pro C720 on their 1st floor. The stairs are out of the question (too narrow). They do however have a lift large enough to take the width and depth. Problem is, the lift is only capable of taking a load of 400kg, whereas the weight of the C720 is 700kg. My question is, can the c720 be stripped down enough to met this weight limitation?
    Thanks in advance.
  • zed255
    How'd ya manage that?
    • 1024
    I would think it could be stripped down enough, but would it be practical. That would be quite a bit of stripping down to basically only take half of the unit up at a time. Personally I wouldn't suggest it. My thoughts would be to remove the fuser, ITB, all PCUs and dev units, paper trays, ADF, toner hopper assembly and controller boxes at a minimum but I'm not sure that would even be enough.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Zed255 is right it can be done this way,and It is a Bad Idea ! The machine is designed to be delivered in the crate, unboxed on site and removed from the pallet by forklift setup and not moved. Sounds like another bad sales idea........
      Mystic Crystal Revelations
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        For whatever it may be worth, I can't think of any production grade printer, such as the C720, that would be small enough or light enough to fit where they want it.
        Perhaps it's time to look at leasing some new digs?
        • tcs04
          FORMER Techie
          • 1183
          Have stripped and split hundreds of MP7001 size machines for difficult moves but I wouldn't even consider the colour boxes!
