firm ware
  • CrapAimer
    • 296
    firm ware
    Hi All
    tried to load firmware onto Dsm735 (3035), from sd card. Comes up as an error as if the firmware is not on the card, Card is working as i have tried it on another machine.
    Any suggestings
  • TonerMunkeh
    Professional Moron
    • 3865
    Is the machine you've tried it on newer? Machines around that age don't like cards bigger than 1GB.
    Hit it.
    • sandmanmac
      • 3964
      Originally posted by CrapAimer
      Hi All
      Any suggestings
      Did you create a folder called "romdata" and put the firmware inside it? That is the procedure
      • ricoco
        • Jan 2011
        • 122
        Hi All
        Any suggestings
        Yes TonerMunkeh is right.
        Also see if there is any more firmwares under the Dir. ROMDATA.
        I had the same problem and i fix it by take out all data in the SD card and let only the firmware i what for that machine.
        • ricoco
          • Jan 2011
          • 122
          If he tryed in another machine and worked certainly have that Dir.
          • sandmanmac
            • 3964
            OOPS....My Bad! I didn't read closely enough.
