RICOH Aficio 1045 SP mode
  • pexco168
    • Feb 2011
    • 5
    [Misc] RICOH Aficio 1045 SP mode
    i got many af1045 face this problem copy too solid (dark), i think is toner down too much.
    A4 sheet front edge of the paper have toner spillage.
    i try take out toner bottle " sky shoot " about 4 pages, the problem will solve, but when i put back toner bottle machine will down toner, after down toner finish copy A4 sheet front edge of the paper have toner spillage again.
    can i adjust 2209-01 Toner Supply Rate to higher value? default is 60mg/s
    or can i adjust 2802-01 TD sensor Manual Setting VTS to higher value? default is 4.78
  • TonerMunkeh
    Professional Moron
    • 3865
    Try servicing the machine before fiddling with any SP modes. PCU rebuild and new developer.
    Hit it.
    • mikadonovan
      • May 2008
      • 2931
      What he said. These machines run dirty and require a little more vacuum time than some other models. Also make sure the transfer unit isn't loaded up with toner.
      NEVER ASSUME ANYTHING
      • Eric1968
        • 2458
        X2
