Hello everyone, I am looking for some ideas on Ricoh Aficio 2238c that keeps adding and dumping magenta toner. Pulled the developer assemblies. and pile of magenta toner is on top of the magenta developer, around the mating latch with the toner pump/ dev assy.. I tried to lower the toner ratio by switching to fixed mode from fuzzy, and lowered to 1% just to troubleshoot, NO help. It keeps feeding toner, and won't stop.
The color developers seem to have over 80K, on them. The history is not clear from customer. Does this unit do this. if the developer goes past their life of 60K? or does it have another issue with calibration? Appreciate if all you Ricoh techs will give this a try!!
Thank you in advance!
