LOSING MY MIND
  • TONERINMYNOSE
    • Aug 2010
    • 114
    LOSING MY MIND
    Trying to locate a wire harness part number for a savin c9025 which equals a ricoh mp-c2500 the part number shows no harnesses, is there a seperate manual for them????
  • CT Copier Repair
    • Mar 2010
    • 304
    what?
    do you have the parts manual?
    for which?
    where does it go?
    what does it connect?
    what do it do?
    doobie doobie do
    • pocket aces
      Ricoh Technician
      • Nov 2008
      • 72
      use the point to point it has part #s
      • Eric1968
        • 2458
        I don't know which manual you are using but I can find all harnesses. Which one are you looking for?
        • teebee1234
          • 1670
          This is the correct answer..
          • TONERINMYNOSE
            • Aug 2010
            • 114
            Does anyone have the point to point? Im looking for the harness that supplies dc to the door/transfer assembly, looks like it runs into another connector join in the rear near the drive section, then that harness goes to the board.
            • Zeldaman
              • Mar 2011
              • 946
              • TONERINMYNOSE
                • Aug 2010
                • 114
                No there are wires that were clipped from misuse in the harness
                • Joel
                  • May 2010
                  • 46
                  as pocket aces and teebee1234 said it, they are right. you need a point to point
                  • Syscopiers
                    • 9
                    The point to point
