Ricoh 1075 big noise
  • copyalbania
    • Aug 2009
    • 165
    Hello,
    I am servicing a ricoh 1075 and after i have replaced Drum, Developer, cleaning blade, brush, corona unit it made about 20K and a big noise begin.
    The noise it is located in the toner transportation transparent tube.
    I have changed the two gears in the transportation but it happened again than i changed all the transparent tube ( the one that transports the toner from the PCU to the developer )
    I also check the gears behind the PCU but they were OK.
    Also it made 10K copies and the big noise begun.
    I do not know what is it.PLEASE SOMEBODY HELP!!!
  • jonhiker
    • 661
    it could be in the toner recycle auger inside the pcu. also, check the gear on the back of the pcu, they are known to fail. it makes wuite a noise when a tooth or two is broken off.
    • TonerMunkeh
      Professional Moron
      • 3865
      x2. There was an RTB not long after the Martini came out with regard to this. If you get one that keeps breaking the brush drive gear, put an A295 drum in the machine instead of a B070 one when you replace the gear.
      Hit it.
      • Jomama46
        • 2900
        Replace the lower pcu unit
        sigpic
        A+; Network +; PDI+
        • ccchuah
          • Mar 2009
          • 157
          Make sure you don't forget to put back the two pieces spacer.
          • mikadonovan
            • May 2008
            • 2931
            You can shim the gear on the end of the tube auger to to allow better contact between the gears. This has worked for me in the past.
            Originally posted by copyalbania
            Hello,
            NEVER ASSUME ANYTHING
            • Fearless V K
              • 620
              I agree. Cheat the door to make sure this is where the problem is, then whatever you can do to improve the mesh between the two auger gears. open the securing screw hole more maybe and push them together.
              Don't take that toner with me!
