Ricoh 1075
  • Muhammad Ali
    [Error Code] Ricoh 1075
    I have a ricoh 1075 copier ...
    when i start the machine the display shows
    reboot after insert e31 and sometimes it gives error code sc820....
    and also i can not enter into the service mode
    please help me
    thanks and regards
    Ali
  • andym
    • Oct 2008
    • 90
    ADDITIONAL SC CODES PRINTED IN SMC REPORT
    Here is a list of SC codes that are printed in the SMC report but may not appear in
    the operation panel display. Note that the codes that have the same number are
    identified by an additional 4-digit hexadecimal number.
    SC No. Symptom Possible Cause
    820 0001 TLB conversion (store) exception
    error
    820 0002 TLB miss (load) exception error
    820 0003 TLB miss (store) exception error
    820 0004 Read address exception error
    820 0005 Write address exception error
    820 0006 Command bus exception error
    820 0007 Data bus exception error
    820 0008 System call exception error
    820 0009 Break exception error
    820 000A Illegal command exception error
    820 000B Potential sensor exception error
    820 000C Overflow exception error
    820 000D UTLB miss exception error
    820 0010 Allocation 0 error
    820 0011 Allocation 1 error
    820 0012 Allocation 2 error
    820 0013 Allocation 3 error
    820 0014 Allocation 4 error
    820 0015 Allocation 5 error
    Unexpected error in CPU device:
    • Controller board defective
    • Boot monitor or self-diagnostic
    program corrupted
    820 00FF Non-initialization allocation error • CPU defective
    • Local bus defective
    820 0601 Read address exception error
    820 0602 Write address exception error
    820 0605 System call exception error
    820 0606 Break point exception error
    820 0607 Illegal command exception error
    • CPU device error
    820 060A Allocation 0 mask exception error
    820 060B Allocation 1 mask exception error
    820 060C Allocation 2 mask exception error
    820 060D Allocation 3 mask exception error
    820 060E Allocation 4 mask exception error
    • CPU device error
    • ASIC device error
    820 0610 CPU timer 2 allocation set error • CPU device error
    820 0612 ASIC allocation error • ASIC device error
    • Peripheral device defective
    820 06FF CPU master clock error • CPU device error
    • Error in CPU initialization data (ASIC
    error)
    30 June 2006 B064 SERIES SERVICE MODE
    4-35
    Troubleshooting
    820 0702 Command cache error • CPU cache defective
    • Memory error (insufficient speed)
    820 0709 Data cache error
    820 070A Data cache clear error
    • CPU device error
    • Boot mode setting for CPU error
    • Controller defective
    • Insufficient memory
    820 0801 TLB virtual address error
    820 0804 TLB global error
    820 0807 UTLB miss error
    820 0808 TLB read miss error
    820 0809 TLB write miss error
    820 080A TLB mode file error
    • CPU device defective (controller board
    defective)
    820 4002 Single-precision calculation error
    820 4003 Double-precision calculation error
    820 4004 Exception error
    820 4005 Exception mask error
    • mikadonovan
      • May 2008
      • 2931
      If you have the capability to update the firmware (it uses an IC card) I would do that first. Unfortunately on this model there is software that is stored on the controller that can become corrupt. If that happens you have to replace the controller.[QUOTE=Muhammad Ali;209911]I have a ricoh 1075 copier ...
      please help me
      thanks and regards
      NEVER ASSUME ANYTHING
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        please help me
        thanks and regards
        Ali
        E31 is a firmware update failure. SC 820 is related probably to the E31. You need a service technician that can try to recover from the E31, before you take more drastic measures.
        Mystic Crystal Revelations
