error sc500 afico 1018
  • BAAKLINIELIAS
    • Aug 2025
    aficio 1018 start work then after 3 second make the error sc500 ,your help please for better result.
    thanks.
  • hosennet
    • Mar 2007
    • 145
    Symptom:
    Main motor lock
    A main motor lock signal is not
    detected for more than 7 consecutive
    checks (700 ms) after the main motor
    starts to rotate, or the lock signal is not
    checks during rotation after the last
    signal.
    Possible Cause
    1.Too much load on the drive mechanism
    2.Main motor defective
    Good luck
    • TonerMunkeh
      Professional Moron
      • 3865
      PCU's probably siezed. You got another to try in it?
      Hit it.
      • BAAKLINIELIAS
        thanks, the mechanism of the developer unit was blocked .
