SR790 on SP8100Dn it's possiile or not?
  • nobody-here
    • Mar 2008
    • 237
    Hi Everybody,
    according to you is it possibile to install SR790 finisher on a SP8100DN.
    Our Pricelist do not allow this but we hope it's only a commercial issue.
    Thanks for your help!
    Vincenzo
    29 rouge unpair manque.... cous cous....
  • Eric1968
    • 2458
    You need the SR3040 Finisher for this model.
    • nobody-here
      • Mar 2008
      • 237
      I know that. I would like to know if anyone has some experience in using sr790 instead
      In fact sp8100dn is like MP4500/2045/3045 that has possibility to install sr790.
      Otherway Sp8200dn has sr790 in pricelist.
      thanks in advance
      • Eric1968
        • 2458
        Both point-to-point diagrams are for the finisher pretty much the same. I'm sure there's a reason for this incompatibility. I think the only way so see if it works is just connecting one (which is an expensive expiriment).
        • nobody-here
          • Mar 2008
          • 237
          Thank you for you help tomorrow we'll try this we hope not to receive so many sc's
          Sent from my HTC Desire using Tapatalk
          • PinevskiS
            • Jul 2009
            • 284
            Hi.
            Not possible. I used sr 3040 finisher of sp8100 and now replace the printer with SP 8200th finisher is not the same.
            Because the amount of the printer is not the same and bridge unit is not the same.
            • nobody-here
              • Mar 2008
              • 237
              Ok, we tried without success.
              After installation the machine won't work electrically.
              BTW Thank you for your preciuos help.
              Vincenzo
