If you find a machine in the MPC3501 range (Possibly 4501 / 5501 and others?!) which enters sleep mode (AOF) and will not recover without cycling the main power switch, check the Power sub system firmware.
There seems to be an issue with the latest (?) version.
Level D0875560B (F.14) shows in the boot firmware.
Retrofitting level "A" (F.13) or the "Base" version (F.11) appears to cure the problem. I have 9 machines on 1 site which were running various versions and the "B" level failed on each machine.
It's possible that other machines may be running a variant of this firmware.
