how to adjust margin on duplex copy
  • hknwbec
    • 214
    Hi, I have a question on how to fix the margin. When I take duplex copy,the first page has no problem,but on the other side the image has a long stright line on the right side, I try to use service mode related to Feed and change the duplex value,
    but no effect. Which mode is suitable for fixing this problem. Thanks
  • Jomama46
    • 2900
    User tools? copy settings> edit>double sided margins. sets to 0
    sigpic
    A+; Network +; PDI+
    • ss12
      • Jul 2008
      • 289
      Is this for a ricoh machine,because I have the exact same problem on a mpc2800,tried all registration and various adjustments,no difference.I'm gonna have a think over the weekend before I go back,but any suggestions are welcome
      • mikadonovan
        • May 2008
        • 2931
        Do this.
        NEVER ASSUME ANYTHING
        • tcs04
          FORMER Techie
          • 1183
          All ricoh copiers have a 5mm margin shift applied to the second side in duplex as default. Mikadonovan and Jomama46 are correct.
          • hknwbec
            • 214
            Thanks all of you,I will try to fix it on today, This model is aficio 2045s
            • hknwbec
              • 214
              Thanks. the problem is solved
              • ss12
                • Jul 2008
                • 289
                Forgot all about that adjustment,problem sorted thanks for the replies
                • tpolley
                  • 12
                  this setting bugs the hell out of me. every machine i set up gets set to zero.
                  • Jomama46
                    • 2900
                    Me too, brother. If I dont, it would be one of the first service calls!
                    sigpic
                    A+; Network +; PDI+
