Ricoh mpc6501sp sistema friery
  • tulipano
    • May 2010
    • 124
    QUALCUNO SA COME SI INSTALLA IL SISTEMA OPERATVO Fiery SU UNA RICOH MPC6501SP FUNZIONANTE COME STAMPANTE PRINTER SERVER Fiery.
    GRAZIE MILLE
    SOMEONE KNOWS HOW TO INSTALL THE SYSTEM ON A Fiery OPERATVO MPC6501SP WORKING AS PRINTER RICOH Fiery print server.
    IN WHICH I HAVE THE FORMAT PRINTER SERVER. THANK YOU.
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    IF you have the system software you can set the dip switches to the service position and connect a laptop via crossover to reload, Or the preferred method is to use the flash drive utility and load the system on an 8gig drive and install from the flash drive. It's much faster.
    Mystic Crystal Revelations
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3946
      Probably not an issue (assuming that this has worked in the past), but be sure that you have an E7200 Fiery, and not the E7100.
      The E7100 will not work with the MPC6501, only the MPC6000.
      I mention this because when the MPC6501 first came out, our warehouse was shipping the E7100 with it.
      That made for a bit of a panic, to say the least.
