copies are getting blank after 20-30 copies and when i start again the first copy is perfect after 20-30 copies it starts to make blank copies
someone can help me?
Kind of sounds like the charge is not being removed from the drum. Could be the quenching lamp is bad or not working correct or the drum could not be grounded properly.
