MPC2051 Jams with custom paper only when printing
  • mrwho
    Major Asshole!
    • 4299
    I've got a customer that tries to print on a custom paper size but whenever he does it, the paper comes out about 5 centimeters the machine jams. But when he tries to copy onto it, the paper comes out fine.
    The paper size is correctly defined in both the machine and the printer driver. I'm still trying to know what code the machine gives when jamming.
    I really can't think of a reason why the machine would jam when printing but work fine when copying. Any hints are welcome.
    Mascan42
    Ibid
  • tpolley
    • 12
    thats a wierd one. 5cm isn't even enough to cause a paper size error.
    stupid question but are you sure they're copying from the same tray they're having printing jams from?
    have you tried moving the paper to another tray ro rule out feed assy issues?
    i would go to output check and start acuating clutches. turn them on and off repeatedly. if a clutch doesn't click every time its stuck and needs to be replaced. ricoh clutches SUCK.
    the paper is a custom size, they didn't cut it themselves, did they? we had a print shop do that and the paper varied 1/2 inch in size. did they fan it properly to make sure the edges aren't sticking together?
    jam codes can be found on the first page of the logging data.
    • TonerMunkeh
      Professional Moron
      • 3865
      Does it do the same out of the bypass? Bypass trays can be a bit more lenient with odd paper sizes.
      Hit it.
      • mrwho
        Major Asshole!
        • 4299
        Sorry to have taken up your time - the c'ASS'tumer wasn't configuring the driver right...
        Nothing to see here, move along now...
        Mascan42
        Ibid
