Ricoh/Lanier 430c
  • T588
    • Jun 2025
    Ricoh/Lanier 430c
    I've been all over the machine and I can't find it...
    I want the copier to default to "auto paper size" on timed reset.
    Awhile ago we set up a custom paper size in the copier that we use occasionally for one specific job...
    Now whenever you copy anything - you have to manually select the paper size before it will print because the copier is always on custom paper size.
    You select the paper size you need - after a while - timed reset reverts back to custom paper size.
    Thanks for any advice.
