Ricoh/Lanier 430c - Default Paper Selection
  • T588
    [Misc] Ricoh/Lanier 430c - Default Paper Selection
    Ricoh/Lanier 430c
    I've been all over the machine and I can't find it...
    I want the copier to default to "auto paper size" on timed reset.
    Awhile ago we set up a custom paper size in the copier that we use occasionally for one specific job...
    Now whenever you copy anything - you have to manually select the paper size before it will print because the copier is always on custom paper size.
    You select the paper size you need - after a while - timed reset reverts back to custom paper size.
    Thanks for any advice.
  • mikedci
    • Jul 2010
    • 227
    Hit auto paper select on the touchscreen then hit the program button on the top right then program as default then confirm.
    • T588
      Thank you - much appreciated.
