MPC 7500 - 7501 PCU / DEV Compatibility???
  • turbojetboy
    • Aug 2009
    • 279
    I am seeing more of the new MPC 6501 / 7501 versions, my question is has anyone tested the compatibility of the entire PCU assys (D014 3046/7 and D081 2214/6 PCUs) and the compatibility of the dev mix (d081xxxx and d014xxxx) in these models?
  • Comatose
    • Jul 2010
    • 70
    Not tried the PCU but I do know the dev is different for the 6501/7501, using the wrong dev gives major toner scatter problems.
    • teebee1234
      • Jul 2008
      • 1670
      From the PPG -
      Technical Enhancements
      Improvements made to the D081/D082 as compared to its predecessor the D014/D015.
      1. Faster copy speed:
      • Model D081: FC: 60cpm, B/W: 65cpm (Previous model D014: FC: 55cpm, B/W: 60cpm)
      • Note: Model D082, the copy speed is the same as the previous model D015 (FC: 70cpm, B/W: 75cpm).
      2. ADF duplex scan
      3. Shorter warm-up time achieved through development of a thinner pressure roller core:
      • D081: Less than 70sec., D082: Less than 60sec.
      4. Reduced power consumption (Typical Electricity Consumption: TEC) to meet International Energy Star requirements:
      • D081: 8.72kWh, D082: 9.66kWh
      5. Expanded paper handling capabilities
      • For Tray 3 to support the feeding of thick paper up to 256 g/m2.
      • Duplex 60 to 169g/m2 (17lbs Bond - 90lbs Index)
      6. Increased LD writing resolution (1200dpi) in printer mode.
      7. Toner and developer enhancements:
      • New toner contains newly developed wax for meeting new fine-dust requirements.
      • New developer contains the new toner.
      • Note: The new toner and developer are NOT compatible with the D014/D015/D078/D079.
      8. PCU enhancements:
      • The new K-PCU features a newly designed charge grid that enables the components of the drum charge corona unit to be individually replaced in the field.
      • The new color PCUs (C, M, Y) features a newly designed drum charge roller that increases the overall performance and reliability of the PCU.
      9. New peripherals:
      • Multi-Folding Unit FD5000
      • USB2.0/SD Slot Type D
      Following items are the same as the D014/D015.
      1. OPC drum:
      • Target Yield: 450k for K, C, M, Y
      2. Easy installation with automatic developer installation function.
      3. Peripherals:
      • A3/DLT LCT with maximum paper size 305mm x 457.2 mm (12" X 18")
      • 2-Source Cover Interposer
      • Fax Unit.
